ผู้เขียน หัวข้อ: Rooftruss-Roof Steel Structure, Steel Roof Truss  (อ่าน 27170 ครั้ง)
ออฟไลน์ foneyjitt
  • กระทู้: 37
  • Firefox 33.0 Firefox 33.0
  • สมาชิกลำดับที่: 2091
« เมื่อ: 09 พฤศจิกายน 2558, เวลา 22:10:31 น. »
design Steel Structure, Roof Steel Structure, Steel Roof Truss, Advertising Steel Frame, Truss Frames, Steel Column
Roof truss is a structural framework of timbers designed to bridge the space above a room and to provide support for a roof. Roof Trusses We can supply all the light steel frame roof truss, walls, panels and floors needed for your building project.
Protecting the value and life of the buildings you construct is an important responsibility that is critical to protecting your reputation. Few elements in the construction process are as important as the structure of the building. More and more, trusses and framing are considered to be critical to ensuring the security, value and service life of a building.
Light gauge steel is fast becoming a preferred alternative to the traditional building materials such as bricks, mortar and timber in the construction industry, not only because of its superior properties, but also because it is cheaper.
Truss is essentially a triangulated system of straight interconnected structural elements. The most common use of trusses is in buildings, where support to roofs, the floors and internal loading such as services and suspended ceilings, are readily provided. The main reasons for using trusses are: Long span, Lightweight, Reduced deflection (compared to plain members), Opportunity to support considerable loads.
we are able to provide you with an extremely cost-effective means of constructing buildings up to 6 stories in height. All the components used for the building structure are designed to your specifications and stamped by a Structural Engineer licensed in the State in which the project is erected. Our Design/Build System provides you with one source for the design, engineering, fabrication, and installation
The specification and use of light gauge steel truss has seen dramatic growth in the construction market.
สอบถามรายละเอียดเพิ่มเติมได้ที่
คุณวิมลรัตน์ นิ่มเดช (วิศวกรสานักงาน) โทร 090-9075273      neenaknuk@gmail.com
คุณมัลลิกา คาผา (ธุรการประมาณราคา) โทร 090-9073165     pare_va12345@hotmail.com
บริษัท ชาญนครวิศวกรรม จํากัด สาขา 3 ลาดหลุมแก้ว
36/24 หมู่ 2 ต.คลองพระอุดม อ.ลาดหลุมแก้ว จ.ปทุมธานี 12140
Tel: 02-159-0984-88
Fax: 02-159-0989
E-mail: contacts_cne3@channakorn.co.th
Website: http://www.rooftruss-rooftruss.com
Keyword:             Roof truss             Steel roof truss
ออฟไลน์ foneyjitt
  • กระทู้: 37
  • Firefox 42.0 Firefox 42.0
Re: Rooftruss-Roof Steel Structure, Steel Roof Truss
« ตอบ #1 เมื่อ: 15 พฤศจิกายน 2558, เวลา 16:12:45 น. »
ขออนุญาต อัพเดทกระทู้ สามารถดูรายละเอียดเพิ่มเติมได้ที่กระทู้
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #2 เมื่อ: 16 พฤศจิกายน 2558, เวลา 10:10:28 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #3 เมื่อ: 17 พฤศจิกายน 2558, เวลา 12:00:50 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #4 เมื่อ: 18 พฤศจิกายน 2558, เวลา 09:53:59 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #5 เมื่อ: 19 พฤศจิกายน 2558, เวลา 15:39:36 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #6 เมื่อ: 20 พฤศจิกายน 2558, เวลา 08:36:15 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #7 เมื่อ: 24 พฤศจิกายน 2558, เวลา 09:53:12 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #8 เมื่อ: 26 พฤศจิกายน 2558, เวลา 14:48:22 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #9 เมื่อ: 28 พฤศจิกายน 2558, เวลา 21:01:29 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #10 เมื่อ: 05 ธันวาคม 2558, เวลา 13:55:50 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #11 เมื่อ: 06 ธันวาคม 2558, เวลา 13:20:06 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #12 เมื่อ: 07 ธันวาคม 2558, เวลา 18:42:45 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #13 เมื่อ: 08 ธันวาคม 2558, เวลา 22:56:14 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #14 เมื่อ: 09 ธันวาคม 2558, เวลา 21:05:26 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #15 เมื่อ: 10 ธันวาคม 2558, เวลา 19:17:32 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #16 เมื่อ: 12 ธันวาคม 2558, เวลา 18:31:00 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #17 เมื่อ: 13 ธันวาคม 2558, เวลา 14:49:09 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #18 เมื่อ: 14 ธันวาคม 2558, เวลา 17:12:11 น. »
ออฟไลน์ foneyjitt
  • กระทู้: 37
« ตอบ #19 เมื่อ: 16 ธันวาคม 2558, เวลา 17:11:17 น. »
