ผู้เขียน หัวข้อ: RigExpert IT-24 - 2.4 GHz ISM Band Universal Tester  (อ่าน 10339 ครั้ง)
  • กระทู้: 6060
  • Firefox 44.0 Firefox 44.0
« เมื่อ: 19 กุมภาพันธ์ 2559, เวลา 12:12:47 น. »
RigExpert IT-24  (2.4 GHz.)
เว็บ ebay
เว็บ hamsiam.com
RigExpert IT-24 - 2.4 GHz วัดswr ,วัดกำลังส่ง ,สเปคตรัมอนาไลเซอร์ ราคา 12,500.-
เว็บ tenmetershop.com
www.tenmetershop.com
RigExpert IT-24 is a universal, ultra-portable device for testing, checking, tuning or repairing antennas and antenna feedlines of the 2.4 GHz ISM band (operating frequencies are 2.3 … 2.6 GHz).
The following tasks are easily accomplished by using the IT-24:
  • Quick tests of antennas and RF cables
  • Output power measurement of wireless access points and other transmitters
  • RF environment monitoring (in the spectrum analyzer mode)
IT-24 may be used by:
  • Telecommunication providers to check their own wireless data transfer networks
  • Service companies to test the equipment
  • Antenna and transmitter/receiver manufacturers
Technologies:
  • Wi-Fi
  • WiMAX
  • ZigBee
  • Proprietary data transfer protocols
Specifications
Single-point return loss and SWR (standing wave ratio) measurement:
  • Frequency range: 2.3 … 2.6 GHz
  • Frequency resolution: 1 MHz
  • Return loss measurement range: >2 dB
  • SWR measurement range: 1 … 10
  • Otput power in this mode: about +5 dBm
  • Measurement error limits are displayed by the shaded area on the chart. These limits are valid for the 2.4…2.5 GHz range.
SWR graph:
  • 4 frequency sub-bands: 2.3…2.4 GHz, 2.4…2.5 GHz, 2.5…2.6 GHz, 2.3…2.6 GHz
  • SWR display range: 1 … 5
Transmitter power measurement:
  • Power limits: -20 … +25 dBm (0.01 … 300 mW)
  • Input SWR of the power meter: less than 1.5
  • Measurement error: better than ±2 dBm
Spectrum analyzer:
  • Display modes: peak and average levels, density graph, waterfall
  • Bandwidth of sub-bands: 100 MHz (5 overlapping sub-bands), 20 MHz (30 overlapping sub-bands), 10 MHz (60 overlapping sub-bands)
  • Input signal levels: about -100 … -20 dBm
  • Signal level marks: 10 dB/div
  • Receive preamplifier: -10 dB, 0 dB, +6 dB
Interface:
  • Color TFT display, 320·240 pixels
  • Water-proof keypad, 9 keys
  • Multi-language menus and help screens
  • Computer connection via USB port
Power:
  • 4 pieces of AAA rechargeable or alkaline batteries (the charger is not included with the tester; batteries are not charged inside the tester)
  • From a computer USB socket
Operating temperature: 0…40 °C
Weight including batteries: 350 g.
Screen shots
Single-point return loss and SWR measurement
Spectrum analyzer: density graph
Main menu
Help screen
SWR graph mode
Spectrum analyzer: peak and average levels
Spectrum analyzer: waterfall
Settings screen
Self test mode
What's in the box?
  • RigExpert IT-24
  • SMA to RP-SMA converter cable
  • User's manual
  • 4 alkaline batteries (AAA)
  • กระทู้: 6060
Re: RigExpert IT-24 - 2.4 GHz ISM Band Universal Tester
« ตอบ #1 เมื่อ: 19 กุมภาพันธ์ 2559, เวลา 12:27:00 น. »
อีกไม่กี่วันจะซื้อตัวนี้มาใช้ เลยเอาข้อมูลมาเก็บไว้ก่อน
  • Chrome 48.0.2564.109 Chrome 48.0.2564.109
New Comet CAA-500 Mark II -1.8-500 MHz Graphic and Analog Antenna Analyzer
« ตอบ #2 เมื่อ: 19 กุมภาพันธ์ 2559, เวลา 21:50:00 น. »
Shipping: $53.65 (approx. THB1,908.85)
You are purchasing (1) New Comet CAA-500 Mark II -1.8-500 MHz Graphic and Analog Antenna Analyzer
This is a NEW and IMPROVED Comet CAA-500MarkII Antenna Analyzers retain the cross-needle analog function of their predecessor and add a full-color TFT LCD providing graphic and numerical, SWR, total impedance with R and X values, along with frequency and battery indicator.
Comet was the first to offer a wide range SWR analyzer with an oscillator covering 1.8-500MHz. They provided a very accurate, simple to use SWR and impedance analyzer to the Amateur Radio community. Their analog cross-needle meter displayed SWR and impedance simultaneously as you swept the chosen frequency range, instantly providing the information needed to make antenna adjustments.
These new Comet analyzers can scan your desired frequency range in seconds, allowing for quick SWR adjustments. Since both SWR and impedance in ohms are displayed simultaneously, you are able to determine resonant frequency more easily. These antenna analyzers, powered by six AA Alkaline cells, provide up to 10 hours of operation. With their built in trickle charger, you may also use Nickel-Metal Hydride (NiMH) cells.
CAA-500MarkII analyzers have the following features:
* Auto band sweep function: Switch to the amateur band of choice and press the "Sweep Center" button. The chosen band is swept and the SWR graphed in seconds.
* Manual band sweep function: Choose the band, the center frequency, and the bandwidth and manually sweep the frequency range.
* Multiple manual sweeps: The graph will overlay manual sweeps in 5 different colors! Make antenna length, position, height above ground, gamma match adjustments etc., and graph each adjustment in seconds without losing the previous graph!
* 8-16VDC external power or 6 AA Alkaline batteries (up to 10 hours of operation) or use Nickel-Metal Hydride (NiMH) cells
* Built-in trickle charger (for NiMH batteries, only)
* Battery indicator
* Selectable auto-power off
* SO-239 connector for 1.8-300 MHz range
* Type-N connector for 300-500 MHz range
These antenna analyzers retain the simple expedient of analog measurements and add a full color LCD screen to quickly, visually, analyze antenna performance and adjustments.
Now with 3 YR RW ANTENNASTORE WARR!
